i.MX6SoloLite Custom Board Debug Uart4 Enabled
Question asked by changyonglee on Jul 15, 2015
Latest reply on Jul 16, 2015 by igorpadykov
Hi.
Use i.MX6SoloLite EVK Board. and run u-boot-2009-08 & linux-3.0.35.
use debug uart port  uart1. I want to use debug uart port uart4.
Now Setting is
- u-boot
u-boot/board/freescale/lmx6sl_evk/mx6sl_evk.c
static void setup_uart(void)
  /* UART4 TXD */
  mxc_iomux_v3_setup_pad(MX6SL_PAD_SD1_DAT5__UART4_TXD);
  /* UART4 RXD */
  mxc_iomux_v3_setup_pad(MX6SL_PAD_SD1_DAT4__UART4_RXD);
iomux_v3_cfg_t usdhc1_pads[] = {
  /* 8 bit SD */
  MX6SL_PAD_SD1_CLK__USDHC1_CLK,
  MX6SL_PAD_SD1_CMD__USDHC1_CMD,
  MX6SL_PAD_SD1_DAT0__USDHC1_DAT0,
  MX6SL_PAD_SD1_DAT1__USDHC1_DAT1,
  MX6SL_PAD_SD1_DAT2__USDHC1_DAT2,
  MX6SL_PAD_SD1_DAT3__USDHC1_DAT3,
#if 0 // Custom Debug Uart Port
  MX6SL_PAD_SD1_DAT4__USDHC1_DAT4,
  MX6SL_PAD_SD1_DAT5__USDHC1_DAT5,
#endif
  MX6SL_PAD_SD1_DAT6__USDHC1_DAT6,
  MX6SL_PAD_SD1_DAT7__USDHC1_DAT7,
u-boot/include/configs/mx6sl_evk_mfg.h (mx6sl_evk.h)
* Hardware drivers
#define CONFIG_MXC_UART
#if 0 //Original. Custom Debug Uart Port define
#define CONFIG_UART_BASE_ADDR UART1_IPS_BASE_ADDR
#else
#define CONFIG_UART_BASE_ADDR UART4_IPS_BASE_ADDR
#endif
#if 0//Original. Custom Debug Uart Port define.
#define CONFIG_BOOTARGS         "console=ttymxc0,115200 rdinit=/linuxrc nosmp"
#else
#define CONFIG_BOOTARGS         "console=ttymxc3,115200 rdinit=/linuxrc nosmp"
- kernel
kernel/arch/arm/mach-mx6/board-mx6sl_common.h
#if 0 //Original. Custom Debug Uart Port. define
  /* UART1 */
  MX6SL_PAD_UART1_RXD__UART1_RXD,
  MX6SL_PAD_UART1_TXD__UART1_TXD,
#else
  /* UART4 */
  MX6SL_PAD_SD1_DAT4__UART4_RXD,
  MX6SL_PAD_SD1_DAT5__UART4_TXD,
#endif
kernel/arch/arm/mach-mx6/board-mx6sl_evk.c
static inline void mx6_evk_init_uart(void)
  imx6q_add_imx_uart(0, NULL); /* DEBUG UART1 */
#else
  imx6q_add_imx_uart(3, NULL); /* DEBUG UART4 */
#endif
static void __init mx6_timer_init(void)
  struct clk *uart_clk;
#ifdef CONFIG_LOCAL_TIMERS
  twd_base = ioremap(LOCAL_TWD_ADDR, SZ_256);
  BUG_ON(!twd_base);
#endif
  mx6sl_clocks_init(32768, 24000000, 0, 0);
#if 1 //Original !!!!! Custom Debug Uart Port
  uart_clk = clk_get_sys("imx-uart.0", NULL);
  early_console_setup(UART1_BASE_ADDR, uart_clk);
#else
uart_clk = clk_get_sys("imx-uart.3", NULL);
  early_console_setup(UART4_BASE_ADDR, uart_clk);
#endif
Please. source patch or information Doc.(i.MX6SoloLite)
How to enabled Debug port uart4 From the i.MX6SoloLIte evk custom board .
Thank you.
