Hello , everyone, Is anyone configure Kinetis Bootloader in Master mode for SPI .. any code please... and where should i implement that.. i am using IAR IDE and FRDM kl25z Board...i hope any one reply..
Hello Mahammad,
You can use the SPI but as slave with the Kinetis Bootloader, as you can see in its Reference Manual it only supports slave mode:
You can take a look into the Demo Application User's Guide to get started.
Earl.
