Gstreamer and WebM
Gstreamer and WebM
amassa
I'm trying to setup my SABRE-SDP board to stream video from a camera using the WebM format. Has anyone successfully done this before?
Any help is greatly appreciated.
Thanks.
Labels (5)
amassa
Also, I am using: Linux version 3.10.17-1.0.0_ga+g232293e (jenkins@yocto-buildthree)
joanxie
could you give me more detailed information? what web camera do you use and what OS do you need ?
amassa
I have both cameras on the SABRE board, but I think the ov5642 is the only one I've been able to get running. I am running a downloaded Yocto release on the SABRE board. I have it connected via ethernet to a Windows PC. I've used the ov5642-mx6qsdp-stream.pdf doc and was able to get that up and running.
I get errors trying to use vp8enc with webm. I'm not sure if that's needed or not.
Thanks.
