Hi all,
I want to stop the task preemption and mask the ISR simultaneously. Do the function call _int_disable() is enough for this?
Or do I need to call _int_disable() for masking the ISR and task_stop_preemption() for stopping the task preemption as follows?
_int_disable();
_task_stop_preemption();
_task_start_preemption();
_int_enable();
OS: MQX 4.0.2
Note: FIFO scheduling is used.
Akhil
Solved! Go to Solution.
Hello Akhil,
You need to call _int_disable() for masking the ISR and task_stop_preemption() for stopping the task preemption.
Sol
Hello Akhil,
Sol
Dear Sol,
Thank you very much for your quick reply.
Akhil
