Processor Expert doxygen "Pins allocation" not supported
mahi
Hi Community,
the doxygen output of Kinetis Design Studio/Processor Expert is a great feature. But for the controller I indend to use (MKL14Z32VLK4) the "Pins allocation" report can not be generated. It contains only the message "Pins model not supported for the selected target Processor".
Are there plans to add support for this controller in the future?
Or is there a possibility to add the support manually (e.g. by modifying an existing template)?
Martin
marek_neuzil
Hello Martin,
The Pin Allocation Report is supported for the MKL14Z32VLK4 in KDS 3.0.0 + KSDK 1.2.0, i.e. when you create a Kinetis Project in KDS (MKL14Z32VLK4) and select KSDK 1.2.0 and Processor Expert the Pins Allocation Report can be generated, see the screenshot below:
Please note, that this project allows usage of Kinetis SDK components and Init components only (LDD components cannot be used when the KSDK is selected).
Marek Neuzil
marek_neuzil
Hello Martin,
Marek Neuzil
Hello Martin,
Please tell me the version of your KDS, and please screenshot the "Pin allocation " view on your side , and also the error message .
I will check it on my side .
Thank !
Alice
mahi
Hi Alice,
KDS is version 3.0.0.
Here is a screenshot of the doxygen-generated html:
As expected, the rtf output has the same content.
Martin
Hello Martin,
Sorry i have not install the doxygen output on KDS,  could you tell me  where can i install it , thank  !
And then i will check it , then if it really have not support this chip , if you need , i can create a feature request to the related team .
Alice
mahi
Hi Alice,
KDS outputs the documentation in doxygen format by default. It only has to be "converted" to some human readable documents.
Here is some information including installation hints: Automatic Documentation Generation: Doxygen with Processor Expert | MCU on Eclipse
Martin
Hello Martin,
Thank for your information .
I think it is not  only related the KDS  whether "Pin allocation" function included to KL14 chip .
While i know little about this , and i strong recommend you ask Erich on the place you send me the linker above , he is the expert about this .
Hope it helps
Alice
