LPUART (UART0) Rx and Tx polarity select with MKL16Z, KDS and PE
Question asked by Lukas Valda on Jul 14, 2015
Latest reply on Jul 14, 2015 by Lukas Valda
I use MCU MKL16Z64 with KDS IDE, KSDK drivers and PE for peripheral setup. I have a problem with a polarity select for LPUART (UART0). This feature is supported by the peripheral and also the Kinetis SDK API Reference Manual. pdf contains the HAL function LPUART_HAL_SetTxRxInversionCmd, which is intended for this purpose I think. The problem is that this function is missing in the HAL files. Do you know where is the problem or how can I solve it?
Thank you, Lukas.
