i.mx53 UART3 incorrect memory map address
soonwonkim
When I check the i.MX53 reference manual (iMX53RM.pdf rev2.1) for UART3 memory map address, in Chapter2 Memeory Map it is 0x5000C000 for UART3 base and 0x53FC4000 for USB (Port PL301). But in Chapter76 all the base address for UART3 is 0x53FC4000. Can you please confirm which address is correct?
Soonwon
Hi Soonwon
Chapter2 Memeory Map gives correct addresses.
soonwonkim
Thanks a lot for your response!
