daisy 3.10.31-1.1.0 not avilable
ashokp
Hi All,
In Freescale git, the branch "daisy 3.10.31-1.1.0"(meta-fsl-bsp-release) is not avilable. Is it possible to get the same branch?
P.Ashok
Labels (2)
saurabh206
Senior Contributor III
Ashok
You can use daisy branch and use PREFERRED_VERSION_linux-imx_mx6 = "3.10.31" in machine config file which should solve your issue.
Saurabh
ashokp
Hi Saurabh,
We are not able clone the branch itself. The machine config file will create after sucessful coloning on the all required files.
I need the branch "daisy_3.10.53-1.1.2_patch" from git://git.freescale.com/imx. Now this branch was deleted
P.Ashok
saurabh206
Hi Ashok
Here is a list of branch available
  remotes/origin/imx-3.10.17-1.0.0_ga
  remotes/origin/imx-3.10.17-1.0.1_ga
  remotes/origin/imx-3.10.17-1.0.2_ga
  remotes/origin/imx-3.10.31-1.1.0_alpha
  remotes/origin/imx-3.10.31-1.1.0_beta
  remotes/origin/imx-3.10.53-1.1.0_ga
  remotes/origin/imx-3.10.53-1.1.1_patch
  remotes/origin/imx-3.10.53-1.1.2_patch
  remotes/origin/imx-3.14.28-1.0.0_ga
  remotes/origin/imx-3.14.28-1.0.1_patch
  remotes/origin/imx-3.14.28-7D_alpha
  remotes/origin/imx-3.14.38-6QP_beta
Saurabh
