How to compile Kinetis Bootloader 1.1.0 with KDS3.0 ?
NicolasP
Bootloader 1.1.0 is delivered with IAR projects.
I'd like to compile bootloader for my system with KDS 3.0.
Are there some kds project files for bootloader somewhere ?
Nicolas
Jorge_Gonzalez
Hello Nicolas Pinault:
The KBOOT v1.1 does not have a target project for KDS, but KBOOT v1.2 is coming soon (tentatively this week) with KDS projects. Please wait for the release, you can monitor the KBOOT page:
Kinetis Bootloader|Freescale
Regards!
Jorge Gonzalez
Jorge_Gonzalez
Regards!
Jorge Gonzalez
NicolasP
Hello Jorge,
KBOOT v1.2 is exactly what I need. That's perfect.
I am using FRDMk22F board (MK22F51212 target).
I don't understand what are the differences between flashloader, flashloader_loader and freedom_bootloader targets.
My guess :
- flashloader : runs in RAM and is able to erase/program the full FLASH memory once.
- flashloader_loader : runs in FLASH and can erase/program the FLASH memory above a predefined address multiple times.
- freedom_bootloader : flashloader_loader for FRDMK22K board
Am I right ?
Nicolas
Jorge_Gonzalez
Hello Nicolas,
Not exactly, read the definition in KBOOT release notes:
(C:\Freescale\FSL_Kinetis_Bootloader_1_2_0\doc\Kinetis Bootloader v1.2.0 Release Notes.pdf)
So in summary:
-​ Bootloader (tower or freedom): Bootloader firmware that resides in Flash and can be used multiple times.
- Flashloader_loader + Flashloader: The firmware you get from the "flashloader_loader" project can be programmed to the K22 with an external tool (Jlink, U-Multilink, OpenSDA,...) and you get a one-time loader. As stated in the text box, the flashloader project must be built first.
I hope this clarifies.
Regards!
Jorge Gonzalez
NicolasP
Hello Jorge,
That's perfectly clear. I should have read twice.
Thanks a lot for your support.
Nicolas
NicolasP
Hello Jorge,
That's good news !
Thanks.
Nicolas
mjbcswitzerland
Specialist V
Nicolas
In case of anything being missing you can also get KBOOT compatible loaders for almost all Freescale boards and processors from
http://www.utasker.com/kinetis.html
These allow mixing KBOOT, AN2295 Freescale Developer's Serial Bootloader, HIDBootloader.exe, USB-MSD, SD card, Ethernet, UART SREC as desired and builds with the following IDEs with no porting or extra development efforts:
Mark
Kinetis: µTasker Kinetis support
Boot loader: http://www.utasker.com/docs/uTasker/uTaskerSerialLoader.PDF
For the complete "out-of-the-box" Kinetis experience and faster time to market
NicolasP
Hello Mark,
That's an interresting product. If KBOOT does not do the job, this might be a good alternative.
Nicolas
