I am using codewarrior 10.6 and PEG library.
I downloaded freescale embedded GUI converter utilities 3.0, but it convert d4d format and i need peg format.
How convert bitmap to data in peg format?
Solved! Go to Solution.
Alex,
Just got info from team.
You can contact them by to support@swellsoftware.com .
This email address is the right way to contact the PEG team.
Pascal
Freescale Technical Support
Alex,
Pascal
Hi Alex,
The problem has been logged in Service Request under the number 1-3926190796 under PEG Support team.
I've contacted colleague and will keep you informed.
Pascal
