UDP receive bug
Question asked by Eugene Ryabtsev on Jul 2, 2015
Latest reply on Jun 10, 2017 by avm
In MQX 4.2 in rtcs\source\tcpip\udp.c I see the following:
static void udp_return_req2socket_from_rx_queue(UDP_PARM_PTR parms, struct udp_rx_dgram_header * dgram_item)
  uint32_t dgram_size = 0;
  dgram_size = dgram_item->size;
  /* limit for the upper layer recv buffer */
  if(parms->udpword > dgram_size)
    parms->udpword = dgram_size;
  if(parms->saddr_ptr)
    *parms->saddr_ptr = dgram_item->fromaddr;
  memcpy(parms->udpptr, dgram_item->dgram, dgram_size);
  ((SOCKET_STRUCT_PTR)parms->ucb->SOCKET)->LINK_OPTIONS.RX = dgram_item->rx_linkopts;
I'd rather expect it to be more like this:
  memcpy(parms->udpptr, dgram_item->dgram, parms->udpword /* dgram_size */);
This seems to respectively cause and solve a system-crash-sized-problem in our application.
