Can I use 24MHz external oscillator with spread spectrum function to the i.MX6 processor?
Or, is there another way to use?
Tomo
Solved! Go to Solution.
Hi Tomokazu
in general this is not recommended due to restrictions in
sect.2.7 Oscillator tolerance IMX6DQ6SDLHDG
System PLL supports spread spectrum modulation
described in sect.18.5.1.3.3 System PLL IMX6DQRM
Hi Tomokazu
