Dear Sir,
Our customer used i.MX6 Solo and want to know Boundary Scan test can cover i.mx6 IC how many pins. (how many pins can test ? )
I checked some documents and can't find it.
Could you help check and provide it?
Thanks a lot,
Hi Andy
please look at bsdl file and check number of controlled pins
IMX6DQ6SDLHDG Chapter 9 Understanding the IBIS Model
Dear Sir,
I and customer already check you provide documents of link.
We are not sure correct pin numbers for BSDL cover test.
Please help ask or check, then provide it.
Thanks a lot,
PS. BSDL is Chapter 11 Using BSDL for Board-level Testing on IMX6DQ6SDLHDG
