Debugging M4 with Segger JLink
nathanb_
Hello Everyone,
I recently purchased a Segger Jlink and am attempting to debug MQX on the M4 core of a VF6xx with it.  Does anyone have a gdbinit file or instructions for this scenario?  I can only find a gdbinit file for the VF6XX_A5 scenario, and not for the VF6XX_M4 scenario.
Thanks.
Labels (4)
nathanb_
Hello Everyone,
I managed to fix the issues I was seeing.
I had to turn the DAP on inside the gdbinit file and remove some conflicting peripherals from the kernel.
set ((unsigned int)0x4006b008) = 0xf101ff24
and
CONFIG_SND_SOC_FSL_SAI_WM9712 = n
nathanb_
More info on what's going on:
# /usr/bin/JLinkGDBServer -if JTAG -device VF6xx_M4 -speed auto
SEGGER J-Link GDB Server V5.00e Command Line Version
JLinkARM.dll V5.00e (DLL compiled Jun 23 2015 18:28:42)
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      yes
Generate logfile:              off
Verify download:               off
Init regs on start:            off
Silent mode:                   off
Single run mode:               off
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 VF6xx_M4
Target interface:              JTAG
Target interface speed:        0kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V9 compiled Jun 23 2015 10:00:59
Hardware: V9.30
S/N: 609302246
Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
Checking target voltage...
Target voltage: 1.80 V
Listening on TCP/IP port 2331
Connecting to target...
J-Link found 1 JTAG device, Total IRLen = 4
JTAG ID: 0x4BA00477 (Cortex-M4)
Connected to target
Waiting for GDB connection...Connected to 10.42.0.1
Reading all registers
Read 4 bytes @ address 0x0000F4B6 (Data = 0x4848E7FD)
Read 4 bytes @ address 0x0000F4B2 (Data = 0xBF304820)
Read 4 bytes @ address 0x0000F4B2 (Data = 0x48304820)
Resets the core only, not peripherals.
Halting target CPU...
...Target halted (PC = 0x0000F4B8)
Downloading 1024 bytes @ address 0x3F000000
Downloading 4096 bytes @ address 0x3F000400
Downloading 4096 bytes @ address 0x3F001400
Downloading 4096 bytes @ address 0x3F002400
Downloading 4096 bytes @ address 0x3F003400
Downloading 4096 bytes @ address 0x3F004400
Downloading 4096 bytes @ address 0x3F005400
Downloading 4096 bytes @ address 0x3F006400
Downloading 4096 bytes @ address 0x3F007400
Downloading 4096 bytes @ address 0x3F008400
Downloading 4096 bytes @ address 0x3F009400
Downloading 4096 bytes @ address 0x3F00A400
Downloading 4096 bytes @ address 0x3F00B400
Downloading 4096 bytes @ address 0x3F00C400
Downloading 4096 bytes @ address 0x3F00D400
Downloading 3864 bytes @ address 0x3F00E400
Downloading 8 bytes @ address 0x3F00F318
Downloading 1232 bytes @ address 0x3F00F320
Writing register (PC = 0x3f0026ac)
Read 4 bytes @ address 0x3F0026AC (Data = 0x49134812)
Read 4 bytes @ address 0x3F0026A8 (Data = 0x40001000)
Read 4 bytes @ address 0x3F000000 (Data = 0x1F807EF0)
Writing register (SP = 0x1f807ef0)
Starting target CPU...
WARNING: T-bit of XPSR is 0 but should be 1. Changed to 1.
...Target halted (PC = 0x0000F2F4)
Read 4 bytes @ address 0x0000F2F4 (Data = 0xE59F1170)
Read 4 bytes @ address 0x0000F2F0 (Data = 0xE12FFF10)
...Target halted (PC = 0x0000EE30)
Read 4 bytes @ address 0x0000EE30 (Data = 0x5B01F811)
Read 4 bytes @ address 0x0000EE2C (Data = 0x6023021B)
# gdb -x m4.gdbinit
(gdb) LOAD_RAM /home/microcom/Vybrid-Toolchain/J-Link/test.elf
0x0000f4b6 in ?? ()
Loading section .vectors, size 0x400 lma 0x3f000000
Loading section .text, size 0xef18 lma 0x3f000400
Loading section .ARM, size 0x8 lma 0x3f00f318
Loading section .data, size 0x4d0 lma 0x3f00f320
Start address 0x3f0026ac, load size 63472
Transfer rate: 74 KB/sec, 3526 bytes/write.
$1 = 528514800
Program received signal SIGTRAP, Trace/breakpoint trap.
0x0000f2f4 in ?? ()
(gdb) continue
Continuing.
0x0000ee30 in ?? ()
(gdb) continue
Continuing.
0x0000ee30 in ?? ()
(gdb) step
Cannot find bounds of current function
(gdb) continue
Continuing.
0x0000ee30 in ?? ()
(gdb)
m4.gdbinit:
# How to run & debug vybrid using JLinkGDBServer
# 1)  Run "JLinkGDBServer.exe -select USB -device VF6xx_M4 -if JTAG -speed auto"
# 2)  Run gdb client: "arm-none-eabi-gdb.exe –x <script_file>.gdbinit"
# 3)  Run one of LOAD_XXXXX functions defined in <script_file>.gdbinit,
#    using application path as argument.
#        f.i "LOAD_RAM app/path/ram_debug/hello.elf"
# 4) Type "continue" to run application
# verified with JLINK JLinkARM_V466, codesourcery arm-2012.03-56-arm-none-eabi
# LOAD_RAM <my_app.elf>
define LOAD_RAM
    if $argc == 0
        print "missing elf filename"
    else
        # remote connection
        target remote 10.42.0.1:2331
        # reset type - core reset
        monitor reset 1
        # halt cpu
        monitor halt
        # load image, 'pc' is set automatically
        load $arg0
        # load symbols
        file $arg0
        # take stack address from 0.th item of  __vector_table
        print (*((unsigned int *)__vector_table))
        # and set sp register
        set $sp = $
    continue
    end
end
Also -- As far as I can tell, the elf file is being properly identified.
(gdb) list main
    int main (void)
    { /* Body */
       extern const MQX_INITIALIZATION_STRUCT MQX_init_struct;
       /* Start MQX */
(gdb) list responder_task
    *     Upon receiving the message the data is incremented before
    *     the message is returned to the sender.
    *END*-----------------------------------------------------------*/
    void responder_task(uint32_t node_num)
        int bytesReceived;
        unsigned int * data;
        CORE_MUTEX_PTR  coremutex_app_ptr;
timesyssupport
Senior Contributor II
Hello karinavalencia​ and nathanb.​,
Unfortunately, we don't have anything on hand with regards to MQX on the M4 with Segger.
Not sure if the MQX team would have any further input Karina, or, Segger?
Timesys Support
karina_valencia
NXP Apps Support
NXP Apps Support
rendy​ can you help here?
nathanb_
Hello Everyone,
and
dry
What does this do set ((unsigned int)0x4006b008) = 0xf101ff24
And where is this CONFIG_SND_SOC_FSL_SAI_WM9712 = n  (Linux kernel?), and why is this required?
karina_valencia
NXP Apps Support
NXP Apps Support
Thank Nathan  for let us know.
