customizing Uboot for customized board
srinivasaporam
We have got imx6dl customized board, for which we want to port OS. We are following "IMX 6 BSP Porting Guide" from  "Yocto Project" (fsl-L3.10.53_1.1.0_iMX6qdls_Bundle).
wrote "build_u-boot.sh" scripting file in <UBOOT_DIR> (which is working director i.e in our case /home/srinivas/fsl-release-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-imx/2014.04-r0/git)
build_u-boot.sh is as follows:
#!/bin/bash
export ARCH=arm
export CROSS_COMPILE=/home/srinivas/fsl-release-bsp/build/tmp/work/arm-poky-linux-gnueabi-
make distclean;
make custom_board_config
make
when we are compiling this scripting file (build_u-boot.sh) we are getting following  errors:
$bash ./build_u-boot.sh
make: /home/srinivas/fsl-release-bsp/build/tmp/work/arm-poky-linux-gnueabi-gcc: Command not found
/bin/sh: 1: /home/srinivas/fsl-release-bsp/build/tmp/work/arm-poky-linux-gnueabi-gcc: not found
dirname: missing operand
Try 'dirname --help' for more information.
  CLEAN   examples/standalone
  CLEAN   tools
  CLEAN   u-boot.lds include/bmp_logo.h include/bmp_logo_data.h include/autoconf.mk include/autoconf.mk.dep
  CLEAN   u-boot.map
  CLEAN   scripts/basic
  CLEAN   include/config include/generated
  CLEAN   include/config.h include/config.mk
Configuring for custom_board - Board: wandboard, Options: IMX_CONFIG=board/custom_board/custom_board.cfg,MX6DL_LPDDR2,DDR_MB=1024
  GEN     include/autoconf.mk.dep
  CHK     include/config/uboot.release
  UPD     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
/bin/sh: 1: /home/srinivas/fsl-release-bsp/build/tmp/work/arm-poky-linux-gnueabi-ld: not found
  UPD     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  HOSTCC  scripts/basic/fixdep
  CC      lib/asm-offsets.s
make[1]: *** [lib/asm-offsets.s] Error 127
make: *** [prepare0] Error 2
how to solve this error
Labels (5)
daiane_angolini
How did you create you toolchain?
I see from your log:
gcc is not found.
And gcc is supposed to be created by poky. And it's supposed to be under a tmp folder. (because it's what you exported)
