P1020 booting from SD card
shubhasingh
Hi all,
I am having P1020RDB-PC board, i want to boot the board from SD card, i had tried to copy bootloader image in to sd card using boot-format tool, after running the tool the the status says succefully written to SD card, but i am getting the console on SD boot, i had changed the switch settings as of Sw3- 001001.
I am attaching the log om running boot-format tool and config file used with boot-format tool.
Please try to help on this
Shubha
Original Attachment has been moved to: Sd_card_crat.txt.zip
Original Attachment has been moved to: config_sram_p1022ds.dat.zip
yipingwang
Hello shubha singh,
You are using P1020RDB-PC board, why do you u-boot image for P1020RDB-PD, u-boot-sd-P1020RDB-PD_SDCARD-2014.07+fslgit-r0.bin.
Please modify "UBOOT_MACHINES" as  "P1020RDB-PC_SDCARD" in meta-fsl-ppc/conf/machine/p1020rdb.conf, then rebuild u-boot.
$ bitbake -c cleansstate u-boot
$bitbake u-boot
Previously I created a document regarding System Boot from SD/MMC Card with SDK 1.6 images​, please have a reference, if your problem remains, please feel free to let me know.
Yiping
naumgrutman
Hello Yiping,
I got the Frescale box P1020RDB-PA Rev.A CPU Rev 1.0
I am trying to build an SD Card for it since it did not have one... this is the way we got it...
I have found your reply to somebody else on this forum...
According to the table found within SDK manual PA version is not supported...
I have conversed with Pavel  Chubakov you can find the conversation at this link
https://community.freescale.com/message/599482?et=watches.email.thread#599482
he seems to claim that it is possible to build usable SD Card...
I have found within this forum your recommendation to change "UBOOT_MACHINES"  "P1020RDB-PD_SDCARD" to  "P1020RDB-PC_SDCARD"
so I tried to change it to "P1020RDB-PA_SDCARD" but then
when I perform bitbake commands:
$ bitbake u-boot
I am getting errors...
Can't find default configuration "configs/P1020RDB-PA_SDCARD_defconfig"
Do you have any ideas...?
Can you confirm that SD Card is buildable for Rev.A via SDK 1.9 or any SDK...
Or it's just waste of time...????
Naum Grutman
shubhasingh
i forgot to attach the log, here is the log-
shubha@shubha-Latitude-3540:~/build_p1020rdb_release$ sudo tmp/sysroots/x86_64-linux/usr/bin/boot_format  tmp/sysroots/x86_64-linux/usr/share/boot_format/config_sram_p1022ds.dat tmp/deploy/images/p1020rdb/u-boot-sd-P1020RDB-PC_SDCARD-2014.07+fslgit-r0.bin -sd /dev/sde
This host is a little endian machine.
Using disk geometry of 62 heads and 62 sectors/track for CHS translation
SDCard has 3874816 sectors
Read MBR from SDCard:
0x0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0040: 42 4f 4f 54 00 00 00 00 00 09 a6 00 00 00 00 00
0x0050: 20 04 80 00 00 00 00 00 f8 f8 00 00 00 00 00 00
0x0060: f8 f8 00 00 00 00 00 00 00 00 00 06 00 00 00 00
0x0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0080: ff 72 01 00 f8 f8 00 00 ff 72 0e 44 00 00 00 0c
0x0090: ff 72 00 00 80 01 00 00 ff 72 e4 0c 00 00 00 40
0x00a0: 40 00 00 01 00 00 01 00 80 00 00 01 80 00 00 01
0x00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 21
0x01c0: 03 00 0b 13 62 11 00 08 00 00 00 00 10 00 00 00
0x01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa
It is a valid MBR
Found first partition in MBR
First partition seems to be also the last partition
================== MBR ==================
boot_ind         = 0x0
start_head       = 0x21
start_cylesec    = 0x3
part_type        = 0xb
end_head         = 0x13
end_cylsec       = 0x1162
rel_sectors      = 0x800
total_sectors    = 0x100000
Read DBR from SDCard at sector 2048 for partition size of 1048576 sectors:
0x0000: eb 3c 90 6d 6b 64 6f 73 66 73 00 00 02 10 10 00
0x0010: 02 00 02 00 00 f8 00 01 3e 00 3e 00 00 00 00 00
0x0020: 00 00 10 00 00 00 29 c1 73 06 93 20 20 20 20 20
0x0030: 20 20 20 20 20 20 46 41 54 31 36 20 20 20 0e 1f
0x0040: be 5b 7c ac 22 c0 74 0b 56 b4 0e bb 07 00 cd 10
0x0050: 5e eb f0 32 e4 cd 16 cd 19 eb fe 54 68 69 73 20
0x0060: 69 73 20 6e 6f 74 20 61 20 62 6f 6f 74 61 62 6c
0x0070: 65 20 64 69 73 6b 2e 20 20 50 6c 65 61 73 65 20
0x0080: 69 6e 73 65 72 74 20 61 20 62 6f 6f 74 61 62 6c
0x0090: 65 20 66 6c 6f 70 70 79 20 61 6e 64 0d 0a 70 72
0x00a0: 65 73 73 20 61 6e 79 20 6b 65 79 20 74 6f 20 74
0x00b0: 72 79 20 61 67 61 69 6e 20 2e 2e 2e 20 0d 0a 00
0x01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
================== DBR ==================
jmp_code[0]      = 0xeb
sector_size      = 0x200
root_entries     = 0x200
small_sector     = 0x0
sectors_p_fat    = 0x100
It is a valid DBR
Configuration file is for a non-PBL boot
Updating boot image length to 630784 in configuration data
Checking if FAT partition needs to be shrinked
Writing image to SDCard...OK.
Writing MBR to SDCard...
OK.
Writing DBR to SDCard...
jmp_code[0]      = 0xeb
sector_size      = 0x200
small_sector     = 0x0
OK.
Updating configuration words in target image ...
Reading sector 0
Writing sector 0
OK.
Congratulations! Completed successfully.
yipingwang
Please check whether the switch setting is correct.
SW2  01111111
SW3  00100110
Yiping
shubhasingh
Hi yiping,
I tried changing the UBOOT_MACHINES as  "P1020RDB-PC_SDCARD, burned the bootloader in sd card using boot-format tool, i am attaching the log of boot-format tool.
When i tried booting the board with the SD-card, led near the battery module, and U32 remains blinking and no output on console.
whereas in case of nor that led doesnot blink, i had followed section 1 and 1.2 from the shared pdf, but getting the board booted up from sd card.
Shubha
