Where can I find the latest version of CCS API and CCS Server.
saqlainraza
Hi Everyone,
I want to use CCS API for communicating with CCS Server in order to debug a target using CodeWarrior USB tap. Can someone please tell me that from where can I download the latest available version of these utilities both for Microsoft Windows and Linux hosts.
Thanks.
Tags (3)
jiantang
I need this document.if you have get,can you send me a copy? qmmt@sina.com.thanks.
TICS_Fiona
Hello Jian
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - You will come to a login page.
  - Click on “Create Service Request”.
  - You can submit your request through the web from there.
Or send mail to support@freescale.com.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
jcrigby2015
I need this also for remote debugging a p1010rdb from a linux host.  Is it available for download from some public place?
TICS_Fiona
Hello John
Best Regards
Fiona Kuang
TICS_Fiona
hi
I see the same question in SR#1-3899590816. What is the part number of your MCU or Processor?
Fiona Kuang
saqlainraza
Thanks for the response. I would like to debug different CPU's like P4080,  P2020 and T4020 using CCS API, CCS (Code Warrior Connection Server) and Code Warrior USB /GIGA TAP.
I know that it is possible to use CCS API functions like "ccs_open", "ccs_read_mem", "ccs_read_reg" etc to actually connect to CCS and debug a target CPU using Code Warrior Probe. I need to get the latest versions of these utilities.
Your support is highly appreciated.
Thanks.
TICS_Fiona
The latest version should be build 426. I have contacted our engineer, and she will send it to you by TransWeb.
Fiona Kuang
healy
I also want to this utilities to develop a Hawk V3 memory read & write tool, can you sent me 1 copy of it?
thank you so much!
saqlainraza
I am unable to open this provided link. It says webpage not available.....
Am I missing something ?
saqlainraza
Thanks for the help ! By when this delivery is expected ?
Regards.
