When I run aprogram in KDS ,the following error shows up.
"The target endianness is set automatically (currently little endian) "
Why does this error occur? Please help.
Dona
Hi dona,
can you shar a screenshot? I believe this is a message coming from the Segger J-Link debug firmware, and is not an error, but an information message. You can tell the Segger J-Link GDB server if it shall use little or big endian, and by default the firmware selects it automatically based on the device used, which is little endian for ARM.
I hope this helps,
Erich
