I have KDS 3.0 (with the SDK added) and KSDK1.2.
Since that did not work, I created my own workspace and added the demo projects to it. One for the library and one for the app.
I built everything fine and tried downloading it to the FRDM-KL27Z board using the pne driver. I get an error message, and it aborts, but the app does get loaded into the board.
Error in final launch sequence
Failed to execute MI command:
-target-select remote 127.0.0.1:7224
Error message from debugger back end:
127.0.0.1:7224: The system tried to join a drive to a directory on a joined drive.
when connecting board, go to windows device manager and check what's the firmware interface. is it P&E interface or OpenSDA or Jlink?
please make sure you choose the right connecting interface,
here is the manual including how to run a board.
http://cache.freescale.com/files/soft_dev_tools/doc/user_guide/FRDM-KL27Z-QSG.pdf?fpsp=1
can this help?
Zhang Jun
