fsl_soundcard.h error
kalden_srcinc
At the bottom of fsl_soundcard.h you have:
#if defined(__cplusplus)
extern "C" }
#endif
For this to compile, it should instead be
#endif
ivadorazinova
Hello Kevin,
Thank you for your feedback.
You are absolutely right. If you compile the code in c-compiler it is ok, but the error occurs if you compile the code in cpp.
Thank you for that, in next release it will be fixed.
Have a nice day!
Iva
