LS1021A-IOT u-boot rebuild with Yocto Project
myungjinhwang
I'm following below command to rebuild u-boot
4. Rebuild u-boot
   $ bitbake -c cleansstate u-boot-ls1
   $ bitbake -c patch u-boot-ls1
   $ bitbake -c compile u-boot-ls1
   $ bitbake u-boot-ls1
first time, it's ok but after build, i modify and rebuild many times.
then modified files are not effective. so i have to command "bitbake -c cleansstate u-boot-ls1".
then modified files are deleted.... so i'm doing backup files and merge again after clean / patch.
how should i rebuild many times.....?
or to build u-boot with yocto project, should i clean every time?
addiyi
You can use something like this to modify and apply your modification to uboot build.
Modify the uboot sources
Also, if you don't want to delete your files every time you modify uboot sources you can use:
$ bitbake -c compile -f u-boot-ls1
Adrian
addiyi
Adrian
myungjinhwang
thanks.....
what is the -f option?
addiyi
-f will force uboot recompilation.
Adrian
