Problem with mingw32-make and .bat files
Question asked by Fernando Lima on Jun 23, 2015
Latest reply on Jun 24, 2015 by Pascal Irrle
Hello everybody.
I'm having problems with codewarrior v10.6 version eclipse.
I can not compile any project, including sample projects.
When I try to compile, the following error appears:
"C:\\Freescale\\CWU_v10.6\\gnu\\bin\\mingw32-make" -j8 all
process_begin: CreateProcess(C:\User\....\Local\Temp\make7036-1.bat,C:\User\....\Local\Temp\make7036-1.bat,...) failed.
make(e=2): The system can not find the specified file.
mingw32-make: ***[Sources/main_asm.obj] Error 2
For some reason, the compiler is unable to generate the .bat files.
Does anyone know how to solve this problem?
