CW 5.9.0 MCP5604 C List file
Question asked by Dermot Murphy on Jun 22, 2015
Latest reply on Jun 24, 2015 by Fiona Kuang
Is there any way to generate a list file from each C file within the IDE?
The disassembly file is not sufficient, as I am trying to compare a build from within the IDE to one created using a make file.
Alternatively, is it possible to generate the command line which the IDE is using at the point of compiling a C file, and later the command line which the IDE is using at the point of linking?
The make file generated ELF runs ok, whereas the IDE created ELF links, but does not run ok.
regards
Dermot
