Dear all,
we cloned the freescale git server and when we try to build it with bitbake we got following error message
ERROR: Fetcher failure for URL: 'http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//imx-gpu-viv-5.0.11.p4.3-sfp.bin;fsl-eula=true'. Checksum mismatch!
File: '.../imx-gpu-viv-5.0.11.p4.3-sfp.bin' has md5 checksum 5642e50b29edcbef0535bdbb015705db when 41f9d590c9a5b703571a3aedbe200bda was expected
If we change the md5sum the unzip process doesn't work, so it seems that the file was damaged on the server.
Kind regards
Wolfgang Netbal
Hi Wolfgang,
Correct, please try just:
wget http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//imx-gpu-viv-5.0.11.p4.3-sfp.bin
or You should try with 5.0.11p4.4 hfp
Hope this helps
Hi Bio,
if I download the file using firefox by clicking on the link in your post I get a file with 100MB and the correct checksum,
if I use wget as you suggested I get a file with 900KB with the wrong checksum.
wget reports that the size is not specified, do you have any idea whats the reason for this message ?
Kind regards
Wolfgang
