How can I update u-boot image in u-boot console?
Linux kernel and dtb file are referenced in i.MX_Linux_User's_Guide.pdf, but u-boot image and file system are not.
In addition, SD card can update in host PC, but EMMC can only with MFGtool. Is it right?
Solved! Go to Solution.
U-boot after load is working in DRAM, therefore new updated
version of U-boot may be loaded and written in the same manner as
kernel and dtb. Please refer to ucl2.xml file from MFG what is location
of U-boot image on selected media (SD, NAND).
Note : MFG is the most preferable way to deploy images.
Yuri
Yuri
