I wish to use the SABRE development board with the i.MX 6SoloX processor to develop computer vision processing and I require the use of the analogue video input on the processor. Does the SABRE board have access to this feature as I cannot find the 'video in' as an input to the board. The parallel camera connector is not sufficient as a key feature i require is compatibility with various cameras via an analogue video input.
Thank you,
Sam
Solved! Go to Solution.
VADC_IN signals are located on LCD expansion port. Please look at the schematic.
YUri
YUri
Thank you Yuri,
Where can I find the schematic?
Kind Regards,
Sam
