mfgtool2 eMMC flashing
Question asked by Ritesh Panchal on Jun 20, 2015
I am using imx6qsabresd board. And using yocto v3.14.28.1.0.0.
I want to flash image created using bitbake into eMMC of the board.
I refered iMX6 linux user guide. But i am unable to understand.
Please find default cfg.ini and ucl2.xml files.
And if i change the LIST  name=eMMC in cfg.ini and try to open mfgtool2.exe i got error "Iitialize operation failed error code-4".
so what's the problem?
So
1. What's the correct settings for cfg.ini & ucl2.xml for eMMC
2. how to run mfgtool2?
3. what should be the Switch setting of SW6 for flashing?
4. how to add my .ext3 image file?
Original Attachment has been moved to: ucl2.xml.zip
Original Attachment has been moved to: cfg.ini.zip
