About USB Host and Device configurations on K21
Question asked by Rahul Hirve on Jun 21, 2015
Hi all,
I am trying to use USB host and device configuration dynamically on k21 system. I am polling on a USB ID pin and configure host or device based on ID pin detection.
But I need this dynamically happen, so when system is running if I should able to change configuration from device to host or vise-versa.
Currently I can configure system either to host or to device once at time of boot sensing ID pin. But when I change ID pin while system is running then it does not reconfigure and fails for any data communication.
Any suggestions?
Attached in my init code APIs
Rahul
Original Attachment has been moved to: usb_code.c.zip
