Dear all,
I have read the article Android Power Management on i.MX6DQ/DL
and “All PLLs will cut off, just 32KHZ sleep clock living (FSL done)” ,how to check?
could you give me more in details?
Thank you~
Hi tony
one can output necessary clock to CLKO1,2 pin and check
it by oscilloscope using register CCM_CCOSR, add debug code
to sources or use memtool for writing to CCM_CCOSR.
Hi Igor,
If I find Some PLLs isn't cut off, how to cut off?
3Q~
