Dear community,
We design the custom board .
We need information about PWM output pin behavior.
After the PWM register setting is completed,
we disable a PWM channel_xx by the PWM Control and Status Register (:PWMxx_ENABLE => 0).
Question1.
Then, What is the PWM output state ?
Is it high impedance ?
Question2.
Then, Can the internal keeper be enabled / disabled separately ?
Koichi Sakagami
Solved! Go to Solution.
Hi koichi
1. yes it is high impedance
2. this can be done for some pads (not all), check
HW_PINCTRL_PULLx register descriptions.
Hi koichi
