My problem is that I want to init a device in init_task, but in the main_task I am not able to use the device. if I want to use this device in many different tasks, do I have to init the device in each task, or could I init the device in init_task and can be used in other task? If the device could be init in init_task and be used in other task, how to emplmemt this function? Is there any example project that can help me?
Hello botao,
Please check the example codes located at the path: C:\Freescale\Freescale_MQX_4_2\mqx\examples
I hope this helps, have a nice day
Sol
Hello botao,
Which MQX are you using?
What device do you want to use?
Sol
