Clearcase plugin failed to installed with the following error msg:
An error occurred while installing the items
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]com.ibm.rational.clearcase.ccrefresh 7.6.2.v201309301552, action=).
Failed to prepare partial IU: [R]com.ibm.rational.clearcase.ccrefresh 7.6.2.v201309301552.
Solved! Go to Solution.
Hello Robert,
yes, I have the same issue. I contacted IBM, so we will see if is the problem on their site.
Please, have you tried to install plugin from these sites?
Clearcase plugin for Eclipse download | SourceForge.net
The same procedure, Work with you fill http://eclipse-ccase.sourceforge.net/update/
and you install updates.
After installation you will see the plugin in KDS
I hope it helps you,
Iva
Hello Robert,
please, can you show us to screenshot of the error message?
You can search plugins in KDS 3.0, Help -> Eclipse Marketplace
For example ClearCase you could find under CodeCollaborator (in KDS 2.0),
Or others like SVN: Subversive, CVS: CVS version tree, Git eGit
Thank you
Iva
Hello Robert,
Iva
Hi Iva,
Your procedure works for me. Thanks a lot.
Robert
