I am using b4860. I try to modify source code of dpaa_demo for intercore communicating by replace dedicate channel by pool channel but it is not success. Anyone can help me, please !!!
Hello Nguyen Trieu Lang
Are you trying to implement intercore communication among SC3900 cores?
Can you please specify what code have you changed and what is the failure?
Lunmin
hi Lunmin,
I modify source code of dpaa_demo project at :CW_SC_3900FP_v10.8.3\SC\StarCore_Support\SmartDSP\demos\starcore\b4860\dpaa_demo.
Now I can implement intercore communication but it is success only by using dedicate channel. For example , if I want to send message from core 0 to core 1. For core 0, i must set qman_fqr_params->channel =1 at function appInitQmanFqrParams.
But if i want to use pool channel , when i set qman_fqr_params->channel = (qm_fq_channel_t)(E_QM_FQ_CHANNEL_POOL1) in both core. it is n't success.
Brs,
Lang
