Different vendors licensing
manuelmacias
I use different vendors licensing products in my company
they were all working fine until I created a service for codewarrior licensing.
I use LMTOOLS for licensing distribution and for some unknown reason they only vendor it sees now is metrowoks on port 27000@myserver
is there anything I can do to make my other vendors daemons work.
trytohelp
Hi Manuel,
I think it's the first time I meet similar problem.
By default a floating license is defined on server by a service.
To be running each service must us a dedicated port to avoid problem.
You can launch several services on same server.
Do you have an error on server with other license file ?
Can you check the log file generated for each license ?
Pascal
trytohelp
Hi Manuel,
Pascal
