I have set up TIM with a overflow interrupt. The prescaler is set to precision. I want to set the overflow to exactly 10 msec. The prescaler does not give me a way to set to this time. It also seems that I cannot write to TCNT in the interrupt to control the next overflow time. How can I get the 10 msec I require.
Ray.
Solved! Go to Solution.
Hi Ray,
attached is processor expert demo code for 10ms overflow interrupt.
in the sample, system clock is 6.25M
interrupt frequency is 6.25M/65536=95.367Hz that is around 10ms
can this help you?
Zhang Jun
Hi Ray,
can this help you?
Zhang Jun
Zhang Jun
Thank you.
Ray.
Hi Ray,
you are welcome!
Zhang Jun
