install codewarrior for linux (eclipse ide)
Assaf
hi all.
i managed to install CW using the wizard installation.
while i try to open it - nothing happens.
im using ubuntu 14.04 LTS.
Tags (2)
ZhangJennie
Hi Biton.
the latest CW10.6 doesn't support Linux.
if you work with Kinetis, I suggest you KDS3.0, which can support Linux® 64-bit (Ubuntu 10.04 (deb), RedHat/Centos 7 (rpm))
Kinetis Design Studio Integrated Development |Freescale
can this help you?
Zhang Jun
Assaf
Thank you for your help, I tried install version 10.2, as I said - installation ran successfuly but trying to open the application is get no response.
I've needed that cause I've upgraded to windows 10. Finally I it managed to install the 10.6 version on windows.
