Flash Programming using Ethernet
utsavikalpesh
Contributor V
I am working with TWRK60D100M kit using Codewarrior v10.6 and of mqx v4.0.
Rightnow, I am using USB Multilink universal to download code.
Now my requirement is to download a code using Ethernet Cable.
Can anybody tell me what exactly I need to do???
soledad
You can use an Ethernet bootloader, please check the below application note:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4367.pdf
This document describes how to use an Ethernet bootloader provided by Freescale. It explains how to modify the .lcf and .icf link files of CW and IAR IDEs respectively, in order to add the Ethernet bootloader support for your application.
In addition please check the below link: (Green Hills Probe:)
Hardware Debuggers and Programming Interfaces|Freescale
Sol
