RCW/U-BOOT image where should i write or flash u-boot-ls1021aiot.bin
Question asked by MyungJin Hwang on Jun 11, 2015
Latest reply on Oct 24, 2017 by Ho Sy Tan
there were  files in my sdcard when i get this board but no u-boot-ls1021aiot.bin
   * uImage-ls1021aiot.bin
   * uImage-ls1021a-iot.dtb
   * fsl-image-rds-ls1021aiot.ext2.gz.u-boot
where this board read  u-boot-ls1021aiot.bin? sdcard or flash memory?
i re-build u-boot file and write it to the sd-card as below
-  Rebuild u-boot
   $ bitbake -c cleansstate u-boot-ls1
   $ bitbake -c patch u-boot-ls1
   $ bitbake u-boot-ls1
And followed
* Write RCW/U-BOOT image to SD card with below command
     $ sudo dd if=u-boot-ls1021aiot.bin of=/dev/sd[x] bs=512 seek=8 conv=notrunc oflag=dsync
     Insert the SD card, Power up the board and check U-Boot output is shown on the serial terminal.
    Press a key to stop at the command prompt.
but it still boot with not re-builded u-boot-ls1021aiot.bin
should i flash RCW/U-BOOT image to flash?
then how to flash RCW/U-boot images i can not find for LS1021A-IOT
Help me plz....^^
