Good morning
I have problem in identifying the support of the SDK for the following processors:
Are any of supported???
Thank You
Pietro
Solved! Go to Solution.
Hello Pietro,
thank you for this very good question.
I checked your mentioned MCU and SDK support MCU and there is a main difference - there are different processors,
so there is no direct SDK support, but - I see support of KDS, so you can modify the code for KSDK.
I attach you the guide.
Does it help you?
Iva
Hello Pietro,
Does it help you?
Iva
Dear Pietro,
I am afraid that there is only support for the Kinetis K10 that runs at 100 MHz (MK10DNxxxxxx10 and MK10DXxxxxxx10).
Earl.
/* If this post answers your question please click the Correct Answer button. */
Similarly,
Is the Kinetis K70 at 120Mhz supported by the KSDK?
Thank you!
Hello Joe,
TWR-K70F120M will be supported in KSDK 1.3.
we expect it in Q3.
Iva
