The rtcs shell demo run on a serial port, how to run it on ethernet ?
It was possible on the security_telnet sample which was available with mqx version before 4.0,
I use the mqx 4.1 in wich this demo was removed
best regards
JP
Solved! Go to Solution.
Hi Paul,
The shell is targeted to work with the serial (CDC) interface. But you can also start a telnet session to take contro remotely of the Shell. Please take a look to the _README.txt file in C:\Freescale\Freescale_MQX_4_x\rtcs\examples\shell
Carlos
Hi Paul,
Carlos
