Warning: ROM table: Two components occupy the same memory space
kandhu26
     While programming MK12DN512  using PE micro am getting error message like failed to resume target process. Not allowed to access registers while running. Then i tried with Jlink then it says two components occupy the same memory space. It's new controller and in this new lot am facing this issue with every boards. But same works with my old board also same MK12DN512 controller.
     Plz help me how to come out of this issue. Also error message i have attached here for reference.
ZhangJennie
please refer solution as below:
[SOLVED] Failed connect to freescale mk60n512vmd100 - J-Link/Flasher related - SEGGER Forum
Zhang Jun
