serial console at android lollipop
zetta
Hello
I build lollipop (5.0.2) BSP (L5.0.0_1.0.0_GA) for sabresd_6dq,
kernel parameter had:
"console=ttymxc0,115200 androidboot.console=ttymxc0"
Serial console can output the kernel message, but can NOT typing anything as KK 4.4.3 or older release, why?@
thanks all
Labels (2)
rajeevnair
Hello, if you disable selinux then you will be able to login
androidboot.selinux=disabled
arunsrk91
Hi Rajeev,
Can you please tell me how and where should i set androidboot.selinux=disabled ?
Am not able to set the u boot env arguments as well.
Thanks and regards,
Arun S
zetta
thanks, I try it.
