Hi Sir,
I have a question:
If we are able to have an external PCIe video solution, can we use internal GPU for this external display output?
As far as I know, all display ports of imx6 are routed to internal IPUs. When external video device create a fb device , is it like a imx6 internal fb device can use GPU 3D graphic engine?
Thanks!
Hi JIMMY
yes, one can use GPU with external PCIe video solution,
as GPU works with data located in memory buffer.
