Does dizzy_3.14.28-1.0.0_GA support qtmultimedia ?
rayin
Hi everyone,
    We met a media playback issue with below development environment:
  • Hardware:fsl i.mx6 solo
  • Os:Yocto dizzy_3.14.28-1.0.0_GA
  • Build:
    • MACHINE=imx6qsabresd source fsl-setup-release.sh -b build-wayland -e wayland
    •   bitbake fsl-image-qt5
When we run "/usr/share/qt5/examples/multimedia/video/qmlvideo/qmlvideo -platform wayland", video playback failed, no video display and error occurs.
error log: defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer"
Could you please help me to investigate this issue or let me know the solution to fix it? Thanks.
Labels (4)
gusarambula
Qt has certain X11 dependencies so I would recommend trying with X11 as backend. While Qt can build and boot with Wayland you may encounter errors so I would first discard this possibility.
vardhmanmodi
Hi gusarambula
How to enable qtmultimedia with wayland?
