KE02 and KL02 micro to micro UART communication issues
umsankarkalluru
Hi Isaac Avila,
Thanks for spending time and providing the feedback on this.
The above experiment you did and code I have provided works communicating
from KE02 to KL02, but the actual problem was to communicate from KL02 to
KE02.
I repeated the experiment with custom board with KL02 processor and
FRDM-KE02Z board and i still face the issue of not communicating properly
from KL02 to KE02.
Please find the attached code which will communicate from KL02 to KE02,
Since I don't have KL02 freescale demo board , can you please run the
attached firmware on the above setup you have and let me know if you see
the correct bytes.
Thanks again for your help.
-Umasankar K
Original Attachment has been moved to: KE02_Test_02_06_2015.zip
Original Attachment has been moved to: KL02_Test_02_06_2015.zip
vicentegomez
Just to have it document, you solved it on
https://community.freescale.com/thread/356433
Vicente
