ADV7180 interface in IMX6q sabrelite board
sharathm
I am working on video streaming my target is capture the data from adv7180 decoder chip interfaced to IMX6q sabrelite board through J5 connector, but when i load the kernel and run the unit-Test example mxc_v4l2_tvi.out test i get an error as
ERROR: v4l2 capture:slave not found
what should i do to overcome this issue.
Thanks in advance
Labels (2)
