Should i turn off interrupts when i write(or erase) flash memory in bootload mode?
Question asked by Eunseok Jung on Jun 1, 2015
Latest reply on Jun 1, 2015 by SCOTT THOMPSON
Hi all,
I am programming the bootloader for Kinetis K10 series. I already read an2295 note and use its SW.
When i practiced without any interrupts code, it was working well.
After then, i add some special interrupts for display, measure and communication(uart system).
But the flash write and erase is not working properly.
Should i turn off interrupts for writing(or erasing) flash memory?
My code is based on an2295 sw.
