After streaming is done how to fing vpu encoder parameters.I am using H.264 and MJPEG.Is there any tool to find fps,gop,width,height and bitrate.
Kindly provide the information as soon as possible.
swapna
1.
You may use gst-inspect command to review possible codec parameters
and their default values.
$ gst-inspect vpuenc
2.
Video file may be checked using
2.1.
MediaInfo :
http://mediaarea.net/en/MediaInfo/Download
2.2.
video inspector tool :
http://www.videohelp.com/software/VideoInspector
2.3
Gspot :
http://www.videohelp.com/software/GSpot
Yuri
Hi Yuri,
Thanks alot for responding.Actually i have tried video inspector tool and Gspot by opening .h264 file for measuring encoder parameters.I could not able to open a .h264 file.Can you let me know the freeware software tool toplay .h264 file and measuring encoder parameters.
Looks like the .h264 file is "raw" one - without container headers / wrappers.
You may try using ffmpeg to wrap the "raw" file.
Yuri.
No.H264 contains NAL header informations.It is not raw file.I am having encoded compressed video file format of h264(EncOut.h264).
I want a free tool that will open H264 file and measure the encoder parameters.Kindly let me know the information
