I downloaded MQX, but I don't seem to see code supporting ftp, like there is http. Please advise. Because we need ftp to transfer the setting file to the embedded system.
Solved! Go to Solution.
Hi Eileen,
Which MQX version?
Will guess MQX_4.1.1 or MQX_4.2.
Please review C:\Freescale\Freescale_MQX_4_1_1_GA\doc\rtcs\MQX_RTCS_User_Guide.pdf Section 5.7 and 5.8.
The web_hvac demo can be setup to use FTP Server in the hvac.h header by configuring it to "1":
#define DEMOCFG_ENABLE_FTP_SERVER 1 //DES was 0 /* enable ftp server */
Or
C:\Freescale\Freescale_MQX_4_2\doc\rtcs\MQX_RTCS_User_Guide.pdf Section 5.7 and 5.8
David
Just add to David's good comments, there are a ftp client and a ftp server demo under the following folder
C:\Freescale\Freescale_MQX_4_1\rtcs\examples\shell
Hi Eileen,
Which MQX version?
Or
David
