i.MX53 ENGcm11135.
Question asked by Satoshi Shimoda on May 29, 2015
Latest reply on Jun 2, 2015 by Bio_TICFSL
Hi community,
Our patner have a question about i.MX53 ENGcm11135.
Pleas see the "WinCE BSP Status" in IMX53CE Rev.5.
It says " System does not perform cache maintenance in non-secure mode".
But they found CSSELR setting in the following WCE700_MX53_ER_1105 source codes.
platform\common\src\soc\COMMON_FSL_V3\OAL\ARMV7\CACHE\init.s(42):     mcr     p15, 2, r3, C0, C0, 0   ; Write the Cache Size selection register
platform\common\src\soc\COMMON_FSL_V3\OAL\ARMV7\CACHE\init.s(81):     mcr   p15, 2, r3, C0, C0, 0     ; Write the Cache Size selection register
platform\common\src\soc\COMMON_FSL_V3\OAL\ARMV7\CACHE\init.s(116):     mcr   p15, 2, r3, c0, c0, 0     ; Write the Cache Size selection register
platform\common\src\soc\COMMON_FSL_V3\OAL\ARMV7\CACHE\init.s(155):     mcr   p15, 2, r3, c0, c0, 0     ; Write the Cache Size selection register
platform\iMX53_SMD\SRC\OAL\OALLIB\startup.s(833):     mcr     p15, 2, r10, c0, c0, 0  ; Write the Cache Size selection register
I think the above CSSELR setting is executed in secure mode, so it is no problem.
Is this correct?
Satoshi Shimoda
